OneStudPuppy
- May 18, 2022
- 84
Ok. I am wired up and running, it’s been a long while since I used to electronics geek out. Getting back into the swing of things and reviewing everything running now a debate came into my mind.
Ampere time suggested charge voltage vs panel production. Currently panel is putting out 13.6 volts at 5 amps. Looking at the ampere time charging voltage says 14.2-14.6 under 100 amps. Now average some things are ok lower. But I’m wondering seems panel is more of a float charge capacity.
Some things are ok running lower, but now I debate in my mind will battery ever get to a truly full charge on solar alone with not matching the suggested voltage. (Like I said I’m getting back into electronics and I’ve forgotten a lot) so I’m trying to remember all the little details.
