Coydon
Where do I look to find the best PV wire gauge info for connecting an array to the charge controller?
My 30A CC came with 10' of 10awg wire [edit: looking at receipts, I bought the wire separate]. The booklet for the Epever CC says 8awg is the max PV wire size. Does that just refer to what will fit in the screw connection terminals?
Will's Mobile Solar Power Made Easy book says 10awg is usual, unless it is over 25ft long which would require it to be 8awg. Is that 25' from panels to controller, or the full system length of positive and negative wires?
I've also been looking at this chart:
According to that, to carry the 30A (15A for 24V) my controller can pull 14' from the panels would require 10awg. But this says the length of the negative cable should be included, meaning a 28' total run and requiring 8awg. Does their statement about dividing amperage by two for a 24V system apply here? I thought the controller was still handling 30A at 24V since it delivers twice the W to the battery on 24V.
Also, does the controller limit the feed from the panels to 30A even if they are capable of producing 36A in parallel (39A Short)?
