Panel Wiring Configuration - Assistance Needed
Riaan
Good Day, Please if someone could assist with a wiring diagram?
Not sure how to do the Series/Parallel Connections.
Here are the specs for the Inverter and Solar Panel. I Need to connect 12 Panels.
5Kva Inverter
Inverter Mode:
Rated Power: 5000VA/5000W
DC Input: 48VDC, 117A
AC Output: 230VAC, 50/60Hz, 22A
AC Charger Mode:
AC Input: 230VAC, 50/60Hz, 35A
DC Output: 54VDC
Max. 60A, Default 30A
Solar Charge Mode:
Rated Current: 80A
System Voltage: 48VDC
Min Solar Voltage: 40VDC
Max Solar Voltage: (VOC): 145VDC
_________________________________________________
Panel Details:
Nominal Maximum Power: (Pmax): 365 W
Optimum Operating Voltage (Vmp): 39.8 V
Optimum Operating Current (Imp): 9.18 A
Open Circuit Voltage (Voc): 47.2 V
Short Circuit Current (Isc): 9.75 A
Maximum Series Fuse Rating: 30 A
2S6P
47.2Voc x 3 panels is 141.6V which is too much for a 145V max input SCC
So you can only connect 2 panels in Series.
So 2Series 6Parallel which will need fuses.
Hi Guys,
Please could you have a look at my wiring diagram? Would this work for the Inverter and panels specs I posted previously?
  • PV Wiring.pdf
