Ampster
Renewable Energy Hobbyist
The structural integrity discussed earlier can come from nailing plywood with a specific nailing pattern. In that use it is often called sheer panel not sheating. I doubt there is much sheer strength from solar panels based on four Fasteners per panel, two of which are often share with the next panel. Then then any strength is spread out over less Fasteners to hold the racking to the rafters under the roof. That engineering is for uplift only and does not factor sheer strength.I'd have to wonder if PV panels might add similar strength to the building as a tin roof.
