thescoutranch
- Jul 13, 2022
- 25
This might be a simple question, but if you don’t know the answer (like I don’t) it’s very complicated.
I understand that when the panels are in series the voltage is Cumulative and the current is Constant. What I am not sure of is what happens if one of the panels in the middle of a string is under performing (due to dirt/bird crap/deterioration/kids with a paintball gun, etc - doesn’t matter why, but pretend 1/4 of the panel is covered).
3 identical Clean 400W panels in series
Measured output downstream of #1
should be 40vdc & 10 amps.
Measured output downstream of #2
should be 80vdc & 10 amps.
Measured output downstream of #3
should be 120vdc & 10 amps.
3 identical 400W panels in series - 1 clean / 1 dirty / 1 clean
Measured output downstream of dirty (loss of 25%, 300W output) #2
should be ?vdc & ? amps.
should be ?vdc & ?amps.
If the number 2 panel is under performing when connected in series, does it just contribute less amperage but the voltage output would be the same ie 40vdc, or would the amperage stay the same and the #2 would drag down the other voltages in the series? Or some other combination?
I understand, that if #2 dies completely the whole string would not put out voltage downstream of it (ie open circuit/ old style Christmas lights).
This is part of a bigger question that I will need to ask, but I need to understand this part first, to be able to phrase the next question properly.
Thanks for any input.
Epp
Edited to correct the question. Thanks @squowse
Epp
