So I picked up 20 150 watt panels for 400 bucks the problem is the MC4 connectors have been cut off.
These are 100V 1.5 Amp panels
What I'm thinking of doing is a 2S10P setup.
I started to put new MC4 connectors on all of the panels then I said why am I doing this.
What Im thinking of doing is mounting the panels on a Ground mount rack about 4 or 5 feet off of ground then attach 1 negative lead from the first panel to the positive of second panel. Then run the other ends to a positive and negative bus bar that would parallel 5 of the 10 sets then putting a breaker on the bus bar and repeating this for the other string.
Basically everything would be hard wired which is easier and cheaper than crimping 40 MC4 connectors.
Does anybody see a problem with my logic. The bus bars would basically be a combiner box I make up with glands to keep things waterproof.
So 2 negative combiner boxes and 2 positive bus boxes then off to 2 SCC 60 Amps each at 24Volts. Im a little over on power but don't expect to ever get full output from my array.
