chadmichael
- Feb 26, 2022
- 51
I have two batteries I will put in parallel via a bus bar. These batteries use Anderson connectors. On the plans I've mostly seen people use a bolt on fuse at the batter terminal. Due to the anderson connectors, this isn't possible. If I connect the batteries directly to the busbar, do I only need to put a fuse on the positive terminal of the bus bar -- well, the load side positive side of the bus bar?
Also, is there any difference between a fuse bolted directly onto the positive busbar "terminal", and then the wire going from that to, say my inverter? And a wire bolted directly to the positive bus bar, then, a few inches of that wire to an MegaFuse or circuite breaker? Is it a problem that part of the circuit comes before the fuse, I guess is what I'm asking?
12V OWL - LiFePO4 -170Ah
400 W system per Will's recipe
2200 W Inverter
2200 W Inverter
