I’m making great progress on my install. Batteries are now complete and hooked up in their permanent location with 50% of the solar array providing power. Batteries are CATL, 271 ah x 8 for two 12V batteries. The cells were top balanced in parallel and at the relative same state of charge via BMS status. Knowing they wouldn’t be connected to a charging source for a while I connected them into individual batteries then drew them down to about 50%. The problem is I did that for each individual battery, not the two of them in parallel.
The solar panels have been providing power for a couple of days and when I look at the state of charge via each BMS one is at 95% and the other is at %75. If I just keep them connected and charging will they eventually hit the same SOC?
