I have an existing 4S48P Lifepo4 battery bank put together using 26650 batteries. Each one of these 192 batteries are between 2400 - 2800 mah. Is it okay to add four 25 ah lifepo4 batteries to each parallel string of my existing bank? So technically the battery bank would become a 4S52P bank, but four of the batteries in each parallel string would be significantly larger (like ten times larger) than the rest of the parallel connections.
