The screenshot below from the Victron Wiring PDF. There are 4 techniques for parallel wiring shown. Are there any reasons to pick one over another when wiring for LiFePO4, other than less wire required for some connections?
This is a link to Impact Battery and they are showing that Halfway is the "Perfect" solution, but they are referring to lead acid.
https://www.impactbattery.com/blog/post/how-to-charge-marine-and-rv-batteries-in-parallel
https://www.victronenergy.com/upload/documents/Wiring-Unlimited-EN.pdf
- Posts has identical length wiring so could see some value in identical resistance.
- Diagonally seems to be the most prevalent that I have seen in the forums or videos. If the length of wire coming off Diagonally to the inverter is the same as between individual batts would it basically equal what is being done in Posts?
