MrM1
I'm Here, But I'm Not All There
I am building two 8s packs each with its own 24v 100amp OverKill Solar BMS. I want to keep the main +/- cables between the packs and the busbars the same length. But the negative (-) will have the BMS in the middle so the negative cable will need to be split in two AND also will have double smaller wire. I Plan to use two 6awg cables coming off the battery negative to the BMS connection, and then two 6awg wire from the BMS to the negative Busbar. The Double 6awg should yield an effective 3awg wire size according to this Wire Combiner Calc
Here is What I do not know:
1. What wires size should I make the positive cable if the negative will be two 6awg cables? 3 awg or two 6 awg?
2. If my total length of the positive cable is 18", do I make the Negative 9"+9" ... OR ... do I need to compensate for the width of the BMS so the cables would be more like 7.5" + 7.5" + BMS of 3" = 18 (given the BMS would be about 3" wide) ?
Thanks
Mike
Thanks
Mike
