Solarguy
- Apr 19, 2020
- 17
Hi,
Sorry if the question has been answered already.
I have two lifepo4 batteries 200Ah each and 48V.
Let's call them battery A and B
A has 200A daly bms and the other one has B=100A daly bms. Battery A has around 300 cycles completed and B has almost 180.
Question is: can I connect these two in parallel without any communication between them. Plain + to + and - to - connection.
I actually had both connected and problem is battery B discharges sooner than battery A. The discharge currents are different. Both gives me ~10kwh if discharges separately hence both are healthy. I disconnected them because i feared one going under minimum volt.
Thanks
Thanks
