Update: The client decided to simply move the 2nd inverter next to the 1st one along with its batteries to enable parallel mode using data comms. Now, he needs to lay down new wires to connect the PVs from the 2nd inverter original site (250-400 m distance between PVs and inverters/batteries). The installers are planning to pull thicker 6mm^2 copper wires from the original site back to the new one , use 4mm^2 wires that are already laid down (connecting the 2nd inverter and PVs) and connect them. In my opinion this is a superior solution to running 2 inverters in any configuration and hoping that the phase synchronization without data comms works out long enough in grid outages before critical fault errors or worse events happen.
