Hello Again Folks,
I'm going to wire two 3000w 120v growatt inverters into a parallel 6000w 120v unit. What does that wiring look like at the ac output breaker box? I currently have it in split phase with each unit powering one busbar in the breaker box, with two 15a breakers going out of each bus bar.
What do I need to do differently to make this single phase? Do I need a different box or do I run a jumper wire across the bars? What's the process?
Thank you
Thank you
