Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 23,174
I will be AC charging this system quite often, so the supercap will be useful also for removing the AC charge ripple.
I'm not sure how effective supercaps are at 60 Hz. Do you have data on frequency response or inductance?
Could be electrolytics work better. Although, even if supercaps only present 10% or just 1% of their capacitance at that frequency (impedance is 10x or 100x higher than pure capacitance suggests), could still be beneficial.
I found some curves, but not ESL in a data sheet.
Curve page 6 shows linear decrease in impedance with frequency, expected of a capacitor, only to about 5 Hz:
The capacitor will draw AC current and heat up as it tried to smooth the 60Hz ripple.
The data sheet I found has an amps rms spec. Looks to me like 0.6% of voltage spec would be max ripple, so your system needs enough capacitor to spread out current draw and limit ripple to that amount.
Supercaps are meant to supply current for seconds. In electronics design we use a hierarchy of caps with different value and frequency response. The electrolytic caps in your inverter probably take care of most 60 Hz ripple.
