Hi guys just a quick question.
So the general write ups you see around the net is parallel wiring solar panels means if one is shaded it will not affect the rest of the array.
BUT i keep thinking to myself that considering a shaded panel will drop in voltage and knowing that when wiring miss matched voltage panels in parallel drags them all down to the lowest voltage then would shading not still effect the other panels in parallel to some degree. Not as much as series but still?
