caesarv
I have my Gobel DIY battery box with MB30 cells (304Ah) supplying my 18Kpv inverter. All is working flawlessly but I want to double my storage capacity as the battery pretty much drains each night now that winter is approaching. I have ordered a duplicate battery box, but with MB31 cells (314Ah) because they no longer stock the MB30 cells. The current battery is connected to the inverter via 3ft 2/0 cables. Each battery box has two positive terminals and two negative terminals.
I have two choices:
1. I can run independent cables from the new battery to the inverter's second set of battery input terminals (costlier and messier.)
2. I can run short cables (about 1 ft) from the new battery to the second set of terminals on the first battery which would then go to the inverter via the existing 2/0 cables (cleaner and cheaper.)
The most amperage that each battery will see (both in and out) is about 100A.
If I do use the second method, would it matter which battery (304 vs 314Ah) is first in the chain?
Both batteries have a Pace PC200 BMS and a 4A active balancer. Both have a beefy 250A circuit breaker, but there are no fuses.
Opinions welcome.
I have two choices:
Opinions welcome.
