partial shade for a week
mtts
We had a wind storm a week ago (or 10 days) and some of the forward panels on a mobile rack system, are each on their own pivot that can also slide, to access stuff underneath the rack when it's laid and locked-down flat.
Weeks before the storm, I had cut the zip ties holding the edge down flat, which keeps these big gusts from blowing the forward panels up and over each other. That was for a brief period where I had the entire rack laid down, facing straight up, during peak summer production. I then raised the rack back up on it's pivot, but forgot to strap the end of the panels back down to keep them on the same plane - to stop them from popping up in hard wind gusts.
For the last 10 days to two weeks, I recall that my peak voltage and wattage, and production, was strangely lower. I go up to the rack today, looking for a bad connection, and where the entire rack is supposed to be pivoted towards the sun, with all the panels flat, I find the two of those forward panels that had jumped up and overlapped their adjacent panel, shading about 5%.
That caused hard shading on a section of panel for that time. I corrected the issue, and I can't tell if it's battery charge state or what. Where the panel voltage and overall production then went up, when I corrected the issue, but not as much as I thought it should.
Can hard shading all day long on a small section of two panels cause permanent damage if done for a week or two?
Thanks
If the visual inspection doesn't find anything, disconnect the panels from each other and test each one individually for at least Voc and Isc, if not also for Vmp and Imp if you can test for that.
Follow-up is everything seems OK.
Thank you for the answers, and sorry for not getting back sooner.
Meh, life has this strange ability to get in the way of things and its not all about what happens online. the fact you came back and gave a report helps to close the circle for future people researching the same questions.
