Thank you
@Dzl - you are describing the exact issues I've been fighting myself on as I wrote it. For example, the choice between using ready to go batteries vs raw cells is not one I made yet, your feedback should help determine this (it could be as easy as having a checkbox splitting the two apart)
I agree datasheets are a must, it's why I added them as an option to upload and view, I've also seen some forum threads on specific questions to ask manufacturers - I've written those questions down to try and standardize on the approach of having an equal amount of information for each record.
1. Cell quality/cell grade comparisons will have to come from reviews, unfortunately. Possibly we ask for verified buyers of the cells and follow up with them down the road on results.
2.
Your right, the scope needs to get smaller, raw cell manufacturers should be given their own section. However, we should
link* raw cell manufacturers to the batteries. In regards to resellers of those raw cells, we have to take what the market dishes out; potentially make note of it as being a retailer/ reseller / rebrand vs. direct from the manufacturer
3. I've taken note of the cycle issue - definitely is missing from some, and wrong on other sellers. Unnecessary to compare with at this time.
4. Noted on the shipping - this will be an on-going struggle to keep those up to date, some automation will help. I also added an option in the quotes section to add a quote document for verification.
Taking note of removing cycle from comparisons, I can add in additional parameters for comparisons, any thoughts on which would be good items to compare on that left side menu filter? I have a listing below but can add on others. (I find maximum charge/pulse/continuous to be difficult to get also)
company, brand, origin, certification, chemistry, weight, width, length, height, terminal_type, color, battery_type, warranty, internal_impedance, maximum_continuous_charge, maximum_pulse_discharge, maximum_charge, charge_voltage, discharge_voltage, minimum_charging_temperature, maximum_charging_temperature, minimum_discharging_temperature, maximum_discharging_temperature
