Keith C
Ahhh, the sharks have him.
So I have eight of those monster BYD batteries I'm wrestling with. I need to get them fully charged so I capacity test them, so I can evenly pair them into my 48V system. I need to get them into balance to capacity test them. These batteries are very resistant to a lot of the typical solutions. Taking them apart is a huge painful task I'm not really considering. Because taking them apart is not an option I'm forced to use the original cell leads that are going to the original mystery BMSes. I've abandoned the original (oem) BMSes in place and tapped out of the cell wiring harness the 8 (9) required wires leading to each cell (they're in with 8 individual temp sensors). I've spliced the cell wires into the harnesses for the the standard [OverKillSolar 8s BMS 100a LifePo4 with M6 Threaded Terminals] Style BMSes.
Firing up the BMSes I see the cells all within about 5mV. Putting a lab supply on them they placidly start charging (at about 1A) as I feel my way along. They stay matched until one takes the lead and swoops up to 3.55V where I have the BMS kick off on "Cell Protection". So there I sit with 7 cells at 3.4V and one at 3.55. Dead in the water. The imbecilic balancing provided stops if charging stops instead of "balancing" charging-or-not a "high cell protection" cell. IF the dang BMS balanced the "Cell Protection" cells the entire battery would eventually be ratcheted up to all cells being top balanced. But alas, the system just sits there stalled as the battery is disconnected.
What I'm doing now is unplugging the cell cable and jacking in a resistor shunt across the offending cell which drains it a bit. I have to guess how long to discharge the cell to get it in line with the rest of the herd. It's a total crapshoot! Sometimes the same cell comes back to "cell protect" sometimes a different cell becomes the top-dog.
I suspect this process will wear out the connectors a couple of times and it will take about 3 years to complete doing 8 of these monsters.
Does anyone have any suggestions? Perhaps a passive balancer I could plug in that would automatically take down the high cell so I don't have to play wack-a-mole. (That would be a mole of electrons in this case.)
A limitation is that I'm afraid of much more than 0.5A of balancing current because these batteries use thin circuit board traces to get to the cells.
I welcome any suggestions - out of the box even.
