chrisski
Solar Boondocker
- Aug 14, 2020
- 5,171
What Hydrometer do you use for a specific gravity test? Do you do the temperature correction of .004 per 10 degrees F? Also, what do you consider fully charged for your battery bank since you’d expect a new one to be 100%, but at several years old, perhaps not?
I ask because with the Deka Hydrometer with the floating glass ampule I was recommended, the highest reading on that is 1.280, but to be 100% on my battery with temperature compensation for 80 F where I subtract .008 from each reading, I would need to read 1.285, but that is above what this hydrometer reads.
This is the first time since I’ve installed the batteries that I did a check with a hydrometer.
I did a specific gravity test, and when I compensated for temperature, I got a charge rate of 96% after sitting in the sun with no load on the battery.
The temp compensated specific gravity of 1.270. Battery Temp was 61 degrees. With 1.277 being 100% and 1.258 being 90%.
Not sure if 96% fully charged is good or not. I also suspect the Deka Hydrometer I used is not accurate enough to get me to 100%. The highest reading was 1.280, so to be fully charged to 100%, I would need to read 1.285.
