I've got 33x 450 W solar panels and 33x Tigo TS4-A-O optimizers. Unfortunately the connectors are different brands so I can't connect the panel directly to the optimizer, and even if I could the wires are too short and need to be extended.
The normal thing to do would be to make a bunch of extension chords that convert between the connector brands. But since the Tigo optimizers are supposed to be connected to the panel first, it got me thinking: what if I treat the solar panel and optimizer as a single unit? I'll have to pre-connect them anyway when installing, and the optimizer mounts to the panel, not the rail.
And if I treat them as a single unit, what if I just make their connection to each other permanent? How bad of an idea is it to cut off the connectors on the solar panel and the optimizer (but only the connectors that go to the panel; I would leave the MC4 connectors that connect each optimizer to each other) and use a permanent butt splice (with weatherproof heat shrink, of course) + extension wire to permanently join the solar panel and optimizer together?
It would be both cheaper and, I think, safer/more reliable because connectors are more likely to fail than a permanent butt splice. I'm not sure if it might void manufacturer warranty but that seems like the only downside, perhaps? I feel crazy for even contemplating this but the more I think about it the more I kinda like the crazy idea...
