Ha! Yeah, I was going to say it sure doesn't seem like the official feed from NASA.
the pitch and direction of the blades is opposite each other, so I imagine you’re right.It is interesting that the blades are turning in the same dirrection in the video. I assume they will counter-rotate in flight in order to keep the body from spinning.
At least put some cells on the blades for self cleaning.I'd be embarrassed to show off such a small solar array.
And I think they ought to hose off that dust.
I can see this becoming the basis for the next round of conspiracy theories proving we didn't actually land on Mars.It is interesting that the blades are turning in the same dirrection in the video. I assume they will counter-rotate in flight in order to keep the body from spinning.
I wonder if the solar array is an “off the shelf”, so as to reduce costs, or a custom, Unobtanium unit.
I wonder how much shading that dust is causing? And how might that affect charging?I'd be embarrassed to show off such a small solar array.
they have to have a way to manage this. i dont imagine they’d launch a bot to a sandy dusty planet, planning on using solar panels, without a plan to accommodate maintenance. maybe flight itself is enough to stir up and remove enough of the dust on a regular basis?I wonder how much shading that dust is causing? And how might that affect charging?
Hum, looks like it may be sourced at that infamous prime 2 day shipping place. ?
DOH!
Certainly possible the thing will make enough wind to clear the panels. Also possible it will stir up enough dust to cover the panels again. That is why this is considered a test. They don't expect to do any science other than figureing out if the thing will actually fly in the martian atmosphere.they have to have a way to manage this. i dont imagine they’d launch a bot to a sandy dusty planet, planning on using solar panels, without a plan to accommodate maintenance. maybe flight itself is enough to stir up and remove enough of the dust on a regular basis?
