This is my first post on this site. I will describe what I have and what I want to accomplish in multiple phases. I also want to maintain part of the existing house battery system.
The vehicle is a 2003 Class C 31 foot motorhome with 30 map shore power and an Onan 4000 watt micro quit generator. The single house battery is charged from the alternator and from a 12 volt converter which is integrated into the existing AC/DC distribution panel. To transfer power from shore to generator I need to unplug for shore power and plug that cord into an outlet from the generator.
Goals of the project are to:
Attached is a drawing that represents phase one. No specific brand name product is really called out other than the battery.
A couple of notes before you review the drawing and comment. I am not an engineer, the drawing is made from research and discussions with others. Based on my current power usage this system should be sufficient for my needs. I also have not called out a BMS for the battery.
Thanks for the comments.
- Have it reversible meaning that I can undo the 24v system easily and put the existing system back in place.
- Use the generator and shore power for charging
- Keep the existing house battery charging from the alternator, but supply no house power from this battery.
- Have a functional 24v system without solar for phase one
- Be off grid for a couple of days without charging.
- I am looking for comments as too will this work efficiently?
- Does the design make sense?
- The only long cable run is on the 120AC side. That would be from the AC output to the inverter to the existing AC/DC distribution panel and from the 12vdc output of the 24v to 12v converter to the same panel. All 24v and 12v cables are under 2 feet in length.
- Lastly is it expandable for the addition of additional batteries and solar panels?
- Or any other comments that will help or glaring mistakes?
