I am looking to connect a off grid solar system to the house electrical system. I have a 24V 1200VA Victron inverter i would like to feed a manual transfer switch via 50 amp plug via breaker / disconnect box. The transfer switch passes the inverter / generator neutral to the neutral on the load center where the ground is bonded to the neutral. I have done a bunch of research and it looks like this will work but I have some wierd voltages from the inverter. With the inverter NOT connected to the house electrical system and with or without the chassis ground on the inverter to a ground rod (Earth ground). The inverter Hot to ground and neutral to ground off the inverter A/C outlet has 60 Volts A/C. Hot to neutral has 120 volts. I checked the inverter and the neutral is NOT bonded to the A/C Ground but the A/C Ground IS bonded to the chassis ground.
Question 1 - Will this inverter 24V 1200VA Victron work in this design?
Question 2 - The Inverter having 60 volts from Hot to ground and Neutral to Ground normal and will this change when the inverter neutral and ground is bonded in the load center?
