Planning new residential system
EscapedAritst
Costa Rica
This is my first solar experience and I'm going all-in on a luxury house. I'm an engineer so I know enough to be dangerous, but I'm a mechanical engineer turned computer programmer so I'm not sure it will help at all with this endeavor. I've studied quite a bit and I'm ready to pull the trigger within the next few weeks. So, I'd like to get some feedback on my thinking process and see if I've gone wrong somewhere or if I'm missing a big piece of the puzzle. First I'll list my parameters. Then spec some options (mostly Will Prowse recommendations). Then expect some of the experts here to tear me apart :)
I am targeting 20KWh to 25KWh daily usage based on filling out many different "calculators" but mostly just looking at electric bills from similar sized/equipped houses (3 bed, 3 split a/c, pool, spa, gas stove/dryer, solar hot water, no need to pump water, etc.)
I will use an LPG generator to charge batteries and supply power when usage outstrips storage plus current solar generation
I only want enough battery to cover for one day (I'll add more if I find I'm using the generator too much)
I want to over-panel a bit for overcast days
I live in Costa Rica on the south west coast and am assuming 4.5 hours of sun average
I want a 48 volt system
I have plenty of space to rack panels and batteries. No tree problems.
I am on a budget...only meaning I don't want to waste money on name brand quality...I definitely want a quality system
I want a split phase 120/240v output to a standard home electrical panel
I would like to be able to connect the system to the grid for a hybrid system one day if they bring the lines close enough (optional if it costs too much to do now)
From studying I am considering the following build options and would love comments:
Battery options (~$12,000):
6 EG4 48v 5.12KWh (favorite option but can't find in stock)
12 SOK 206ah 12v batteries 4s3p to achieve 30kwh storage at 48v (I don't need to protect for cold :)
2 Energy Tech 13.4kwh 48v (not in stock)
3 Energy Tech 10KWh 51.2v 200Ah
Panel options (~$3500):
16 Mono Perc 72-cell 445W panels for 32kwh of avg. daily generation. 8s2p for 320Voc
Inverter options (~$6000):
4 parallel MPP Solar LVX6048 Inverters for split phase 120v - 240v 100amp
Generator (~$6000):
Generac Guardian 24KW generator for charging batteries when the batteries are low and no solar available
Things it would be good to know:
Is there any sense in adding a separate solar for pool pumps...just hook some panels directly to the pump and pump while the sun is shining? Anyone have brand/model ideas? This seems better than adding yet another high power device on the batteries.
I'm assuming the Inverter would be the limiting factor on surge requirements, but think that it is important to understand the batteries play in this. How do I spec the maximum draw the batteries can take in or dole out? I assume the inverter protects both input and output to and from the batteries?
I haven't factored in a peak load because I don't really know what it affects or how to estimate the number. Obviously, you can estimate the number by adding up everything in the house and turning it all on at the same time. But I can't figure any way to lower that without making crazy assumptions.
Should I add more panels for charging and running high power devices simultaneously when the sun is shining?
Where do I buy all this stuff? These are some places I'm sniffing.
https://www.currentconnected.com/
Welcome to the forums!
...if I'm missing a big piece of the puzzle....
The DIY Checklist might have some steps, or if you spot something missed let's get it added!
If you have don't have air conditioning or electrical heating that sounds right, but otherwise may be off in winter or summer. (I see you have 3 mini-splits, might want to double-check that usage). In regards to battery, high-altitude/low-humidity locations (e.g., Denver) or super-insulated homes may only need to run the Air conditioning during the day and can "coast" through the night with a "smart" thermostat, that can save a bundle on battery costs.
The 4.5 insolation is probably the annual / average insolation. Take a look at your power use in winter and summer and the insolation for each of those times. Given your location, you may also want to use SAM, for example, my 6.5 summer months also come with a lot of rain, so it might not be reasonable to tilt specifically for summer.
I wouldn't, otherwise you might end up throwing away power that could have been used to recharge your batteries.
Surge depends on the motor, it can be really high (figure +15% of the LRA). Mini-splits typically have variable speed motors that start slow and ramp up, so they shouldn't be an issue. Your spa pump, washer, dryer, freezer might be (especially if they all try to come on at the same time). If the spa pump is a problem, you'd probably be best off replacing it with a variable-speed, but you can also get a softstarter.
Batteries have a maximum C-Rate, make sure you're well under that for normal draw and surges shouldn't be an issue, more on that in the battery FAQ.
Growth
You can get inverters with a "parallel" feature that allows multiple to be connected together, the big advantage to that is it lets you grow rather than fork-lift; the downside is they usually need to be equally paired so if you get a 5 and discover you need a 6 you might decide to fork-lift anyway). Mincroinverters are the cats meow for expansion, but they can be expensive as you end up not being able to mix/match batteries yet (e.g., dependent on a single vendor), see Ensemble (solution might just be months away though).
The max is provided by over-current protection (aka circuit breakers/fuses). You size those to the wires and then control underneath that by turning stuff off.
The inverter will "trip" if it can't supply enough power. Some will auto-reset, some require a manual intervention.
Be sure there's a low-voltage cut off to protect the batteries, preferably something you can adjust so you're in control of your batteries life-cycle rather than what the factory believes is best for you.
If you want you can DIY a battery bank for half the price
2x 16x EVE 280 (or CATL 302Ah) cells $5500 (28.8 kWh) + 2 JK Heltec BMS &450
You have 4 inverter, you can have more. The sun is not always shines at max :)
Good choice. Sol-ark is Nr1 but expensive
Generator (~$6000):
MPP Solar has batteryless solar pump invedter.
Max charge and discharge at 0.5C.
2x 280Ah = 560Ah ... /2 = 280A
This is the max charge and discharge for your LFP battery.
So you can have 280A x 48V = 13.4 KWp solar panel.
Also your consumption should be less than 13.4 kW
If you double the battery this values double too
Also if EV then best charged directly from sun :)
Damn, what a great bunch of info you guys just dumped on me. I'm just digging into the meat of it. Between the SAM software and the DIY Checklist, I'm into a major study session again. I just wanted to thank you all for responding!! I'll be back shortly after I've digested this new information.
On question immediately for mrzed, if I do my own batteries, is there a tutorial you know of that gives the best practices? And, what container would you use for those?
Ohhh there is a lot of video on YT:
Off-grid garage:
The Digital Mermaid:
And you can always ask us.
We even know what they did wrong or not ideal ?
Most use a simple shelve system.
Some use the boxes that is made for trucks.
I want mine to be perfectly water resistant so IP65 cabinet.
Some topic here:
I'm finding that pricing is only "half the price" if purchased off Alibaba. I can't find anything less than about $25/watt
When I look at the prices the only way I can get a half price battery system is to order from Alibaba. Is there a place where I can buy cells in the US?
Off-grid? No. Just use an efficient multi speed pump and run during the day when there is ample solar to cover the pumping cycle needs.
I have a 48V 4kW clone Voltronic PIP inverter and it runs my pool pump without concern. The pump has a very soft start. Ramps up to ~900W over about 30-seconds, stays there for 5-min before dropping back to all day running mode of ~320-340W. The solar PV easily covers that.
My old single speed pump used to suck 1200W all day. Seriously, modern efficient multisided pumps are way better and cut down your energy supply requirements by a lot.
Check this thread (and others). I think Amy (or Basen) has a warehouse in the US (so it is still Alibaba, but from local warehouse).
Hey EscapedArtist. I'm in a very similar situation building a new house in Uvita. I just joined this forum and just posted my own questions about overall system design:
https://diysolarforum.com/threads/b...r-grid-assisted-off-grid-in-costa-rica.33426/
Where is your house?
I'm a bit of a n00b myself but I do marine electrical work as a living including all kinds of alternative energy and batteries/inverter etc.
One thing I noticed in your specs is that you seem to be planning for 100% efficiency from your solar:
445 watts * 4.5 hours * 16 panels = 32 kwh per day
My understanding is that you can only expect about 75% efficiency to allow for imperfect angle, temperature, dust on panels, Toucan poop, wiring losses, etc. One quote I saw from a Costa Rican solar company had a 64% efficiency factor applied to the total PV wattage. That sounds low but certainly 100% efficiency is virtually impossible.
My planned house sounds very similar to size/specs as yours. Largest load is the pool pump and we will have mini-splits which we won't use regularly but we may use for humidity control if we lock up the house. We won't have electric water heater or well pump. I am debating about electrical cooking. Propane costs money and is a hassle to hump the bottles up and down the mountain. But electric cooking can take a lot of power.
Anyway - I'm still working my spreadsheets and considering system topography. My first rough ideas were a minimum of about 10kw of PV, maybe about 12-15kw inverter with higher surge capacity, and min 30-40 khh batteries. In comparison your initial cut is 7.1kw of PV, 24kw inverter, and 30 kwh battery. If you derate your solar as I suggest we are pretty close on PV too.
24kw of inverter would be necessary for 24kw continuous and surges above that. That is a lot of power. Really necessary?
Want to hear more about this design/plan. Keep thread going OP!
So just as l00semarble wrote his query above, I have just received a container in Costa Rica that has my system on it. So, there are no assembly tips, tricks, or errors to report yet, but here is the buy-list that actually got delivered:
  • 4 EG4 6.5KW inverters (they take PV input of 500v max each)
  • 1 EG4 6000EX inverter for 120/240 solar generator. I wouldn't buy this again as I didn't understand the idle consumption is so high. Normal idle consuption on a solar generator is not too important because you can just turn it off, but I'm going to use this as my office backup when the generator is not in use in the field. I'll report back on how this project performs but I suspect I'll be disappointed with idle consumption.
  • 1 EG4 battery rack
  • 7 EG4-LifePower4 48v batteries 1 for the solar generator...the other 6 for the main system. I'm convinced now that I'll need another 6 to keep the generator from running so often. I'll report back on performance in a few months when the house build is done and running.
  • 41 Solarever 455w mono panels - 50v each and with 4 inverters I will hook up thirty six of these in four groups of nine in series (~4kw) and send each of these strings at 450v to each of the four inverters. The remaining panels will be hooked directly to the pool pump and to charge the solar generator and one already broke during shipping but I have a few extra still.
  • 10 Iron Ridge xr1000 rails to mount (I overdid this...but they are beautiful)
  • A peckload of Iron Ridge supports and fittings.
  • 1 Gererac 7209 24kw generator (I got this for $5000 brand new...not sure how that happened but it is here)
I should be assembling over the next weeks and will try to report back twice. Once with a build report and at least once with a performance report.
Wish me luck!
Hi, I didn't even see this message come in. Sorry for not answering it. This is Brice in case we know each other. I'm actually building three places right now, but only one am I reporting on here as the other two will be mostly similar while hopfully working out the kinks. My main home I'm building in Portalon. That is what the spec above is going to service. Your comment was absolutely right about 16 panels. That was an early post and I did some more math and learning. I'm going to start with 36 panels which maxes out my rack, but imagine that even 36 may not be enough in October. Where in Uvita are you building? I have the advantage that even though I've got a bit of a view, I'm fairly low down and get great sun all things considered.
So you sourced everything in the states and shipped it down? Including the panels? I'm going to private message you as I would love to hear about the shipping process including who you used and how you got hammered with taxes..
As for the system it still seems to me that your inverter output capability (26kw) is huge especially as comparted to the PV size and battery size. Are you running 3-4 air conditioners all the time? I assume AC is a major factor for you if you are at low elevation. Is this why you need so much inverter?
You mentioned a target of 20-25kwh/day of consumption. My current house in Uvita is 3BR and we average about 900kwh/month or about 30khw/day and that is not using much Air Cond due to elevation (though VRBO renters do waste power.) I have pulled ICE bills form friends and see some similar lower elevation houses (3BR) in Dominical using about 1100 kwh/month or about 37kwh/day.
If you use 25kwh/day with an constant 24 hour load that would be 25kwh/day / 24 hrs/day = 1.04kw. Obviously the load isn't constant for 24 hours but basically a 1kw load for 24 hours would put you at 24kwh/day. How can you possibly need 26kw of inverter? If you used 26kw for 1 hour you would be over your 25kwh/day in the first hour. SOmething just seems out of balance or you have very high but very short duration loads.
I look forward to hearing about how your project comes together. Maybe we could even get together in Costa Rica (though I'm not there right now.)
I have some numbers on Clearness index and monthly average sun/day for Uvita. I got this from a solar installer in Costa Rica but it seems to jive with what I can find online too. I have been using 65% as total efficiency from rating of panel to final burn in an household load.
Your strings are 4095w and you have 4 so 16,380w total. I plugged this into the spreadsheet I was using and get an average monthly yield ranging from 1,262kwh in October to 1871kwh in March. Divided by 30.4 days that is a range of 41.5kwh/day in October to 61.5kwh/day in March. If your consumption is "only" 20-25kwh/day you should be in very good shape overall ending most days with full batteries unless there is a string of now sun days in a row (which does happen.)
Thanks for that chart!! I am not in any way practiced at this. I'm essentially winging it. However, I've thought a lot about it and this is my reasoning. I'd love to learn anything you can clear up.
You said,
26kW output can deliver 216 amps. That is excessive for the house, but half of that I've guessed is not enough. I would consider a home with a/c's, water jets for the jacuzzi, a workshop in the basement, 15 ceiling fans, etc. a 100 amp service as under powered. So, I went for basically a 200 amp service. That being said, this is all theoretical. On my next system I plan to be more experienced with the reality of a home here in Costa Rica with a lot of gas appliances, solar hot water, solar pump for the pool, etc. You could be right!
The batteries - for sure - are not enough. I just don't know how many more to buy. As soon as I get data I will add more to the system.
The PV, however, is an open question. I think I have enough, but maybe not.
So for both of these questions, I have a 24kw generator. My plan is to learn as that gets used (both when and how often). Then learn and buy what is needed. I understand that adding new batteries to older ones is not ideal, so I will make this study as soon as the rains start in May and then get some more.
Sizing inverters is for those times when a lot of appliances kick in at the same time. It doesn't matter if you are only running 10 kwh per day, if you run 25kw for 5 seconds its going to trip. I really don't want the house ever to trip.
