roadrunner
- Mar 12, 2021
- 158
Here's my thoughts, I have a swamp cooler to cool my home (mobile home), it uses 222 watts when running on low, 120 volt, 440 watts on high.
Fridge uses 125 watts when it kicks on, 4.24 KWH in 48 hours time, no big deal.
I want to purchase 2x 100 watt panels, and a 600 watt, grid tie inverter, with a voltage of DC 11 to 32 volt input.
The panels will have a VMP of around 18 volt per panel,
So i can wire panels in parallel to keep vmp at 18volts.
Then, build a suicide cord, to run from inverter to a plug in 15amp breaker power strip. The one that has breaker on top of power strip.
This would plug into the same 120 volt outlet that my swamp cooler is plugged into, which is on the main panel with a breaker.
So, my scenario would be this, get up, and turn cooler on, then switch on circuit breaker on power strip,
This way, no current will back feed to grid because my 2 panels should not put out more than 200 watts even on a perfect day, which never will be because they will be flat mounted on my shed roof.
Now when the sun goes down, i will loose power and then just turn off breaker on power strip. Hopefully i don't forget to shut off breaker,so it doesn't back feed in the morning.
I have been installing solar panel grid tie syastems for 6 years and am a res and comm electrician, so i know all the no don't do that suicide cord, ect.
I have also thought of building a small gfci plug in box for this setup instead of using a power strip.
Just trying to lower my monthly summer bill because of the cooler, that"s it, if i can save 50 bucks a month im good, and not get caught.
The other way might be to see about wills video on that solar setup with the 12 volt inverter that doesn't back feed.
The other reason for doing this is to have a battery backup for emergency's. Also.
