John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
Makes no sense to have 0 awg with a 170 amp fuse on the inverter and 1 awg with a 125 amp fuse on the battery.
Suggest you either swap them or make them the same.
The buck converter has a common negative.
That means both the 12 volt and 24 volt negatives connect to the common negative terminal.
What is the continuous rating in amps for the bms?
How far between the busbars and the 12 volt fuseblock roundtrip?
