Hello,
I have a Ecoflow Delta Pro in the house and want to connect a freezer in the garage. The garage is about 50 ft disconnected from the house and I just ran a conduit with a 10/3 Romex in there with the intend to connect to the 30 amp outlet from the Delta Pro.
The cable is rated for the 30 amp but I would feel better if I had some 'sub panels' on the house and the garage side.
I was thinking about a sub panel at the house that connects to the Delta Pro on its 30 amp outlet. Then feeds into a box with a 20 amp breaker for the garage plus one 10 amp breaker for the house and a second sub panel on the garage side with two 10 amp breaker for two circuits.
Can I use these?
Can I use these?
