orangedoughnut
- Oct 25, 2021
- 2
Hey all,
Could I get a sanity check on my system before I throw it together? I also had a few specific questions below.
So, questions:
So, questions:
- Do I need an additional fuse between the solar array and the Growatt?
- Do I need an additional fuse between the batteries and the Growatt?
- The Growatt has a 60A max charge rate and the batteries only have a 50A max charge rate.
- Also, in the Mobile Solar book, there is a solar charge controller fuse (in this case, 80A charge controller, so 100A fuse), but I'm not sure whether that still applies since I have no stand-alone charge controller.
- Am I overpaneled for the batteries? Do I need to remove a panel to drop below 50A?
- Max battery charge rate = 50A
- 1400W solar / 24V battery voltage = 58.3A
