offgridpower
Off Grid Simple Living AZ
- Nov 19, 2020
- 22
I would appreciate your critique of my off-grid solar design pictured below. The system will generate 6400W, with 13.8 kWh LifePo4 storage and a 6000W split phase inverter. It will be a split system with separate 110/220VAC and 48VDC distribution panels and backup generator.
I would especially appreciate your input on: fuse and breaker size and location, grounding, and general wiring. As well as anything else that you may see that is not optimal.
