BulldawgSolar
- Mar 1, 2022
- 45
I have constructed a 48v off-grid system:
- 48v Sigineer 3000w offgrid inverter/SCC/MPPT/
- 8 12v/150ah LiOP batteries (2 x 4 in series)
- 6 string Eco-Worthy combiner box
- 10- 100w/12v panels (2 x 5 in series)
- 9- 210w/12v panels (3 x 3 in series)
The system works great except that I can't get any PV input from the 210w panels. I've tested each panel individually. tested the wires and connections. i've tried different connection boxes. It seems that only the 100w panels are producing (average 750w). The max potential of the system is 2,880w.
I have an extra 4 string Eco-Worthy combiner box and a Victron 150/30 MPPT and I attempted to hooked the 210w panels to the Victron and leave the 100w panels on the Sigineer and connect the PV Outputs from each to the batteries using 2 bus bars.
What I uncovered was almost max Volts but 0 Amps (ergo 0 Watts). In troubleshooting, it said that the MPPT was not connected to or reading the batteries, but it was showing the same voltage as my stand alone battery meter so it must be connected. It also said the Volts with no Amps means "Open Circuit", but how can that be?!?!
The Victron is grounded. The 3 3 x 210w panels are hooked up correctly. I also tried hooking different wires to different sets of panels, hooking different panels together, swapping from 3 strings of 3 to 1 string to 2 strings. I also tried 2 panels hooked in parallel and the voltage dropped in half but still no Watts.
No fuses are blown otherwise the 2 5 x100w wouldnt be working.
Side note: last week when I 1st set up the system and had only 2 5 x100w and 2 3 x 210w I did register 1,600w PV input during ideal conditions which I believe was the result of the 2 100w strings and 1 of the 2 210w strings working at almost max. Also, at times, the new string of 3 x 210w seems to actually make the PV input Watts drop when plugged.
Please help!!
Please help!!
