Firesky567
- Apr 19, 2022
- 25
Hi, I just joined the site today and I am looking for some advice.
This is my first setup and also my first time posting here.
I am planning to use the following components to run my cabin off grid.
- 4x 270W PV Panels in 2S2P https://static.trinasolar.com/sites/default/files/Datasheet-PD05.08D.pdf
- 4mm Solar UV Proof cable / 2x Branch Connectors / MC4 between strings
- Victron Smart Solar 100/50 MPPT
- Victron Smart Shunt 500A
- 24V/100Ah LiFePo4 Battery (+Victron Temp Probe + 7w Heat mat + Inkbird Temp Controller)
- Victron PSW Inverter 1500w
Wiring to a 230V AC 6A Breaker in Consumer Unit to provide power to 13A sockets.
My question is how best to fuse the setup?
I have read that I need not fuse between the 2 strings of panels as they won't generate enough current to damage the cable I'm installing.
I know I need something between the MPPT and Battery, and something between the Battery and the inverter but what is best?
Are DIN Rail mounted DC breakers, in one consumer unit best to keep everything tidy?
Or is this unsafe/unwieldly and should I use inline breakers, albeit more expensive, and I have read bad reviews about them.
Plus they only interrupt + not both +&-.
Many thanks in advance for any help / suggestions. It's more valuable than you know.
I have some formal electrical training but this is all still new to me.
Peace
Peace
