ArthurEld
Solar Wizard
I will definitely be exporting to the grid.
And it does seem like I should be able to use my air conditioner most of the time because it runs the most when the solar is producing the most.
I should be able to connect the air conditioner to the smart loads connection of the Sol-Ark which is programmable based on battery state of charge.
But I want to proceed slowly with my batteries. My top priority is to get solar up and running. I would like to have the system battery ready for the permit inspection. But I don't necessarily need to have the batteries hooked up for the inspection. The Sol-Ark is capable of operating without batteries. If I can get the inspection over with without batteries, that would probably be the smoothest way to go as long as I don't need an additional inspection.
My main breaker is on the bottom so these breakers go on the top. My marking is sloppy. I mean the two 50A that are tied together.
