AZ Off-Gridder
- Nov 25, 2021
- 139
As the Title suggests I am in great need of help. I have Signature Solars 48v Server Rack EG4 batteries. 3 in parallel. And I have the MPP 6548 Inverter all in one. Finally got the system connected but I don’t have all of my panels setup yet. So I attempted to use the AC Input feature with the MPP and I plugged it into my Gasoline Generator. It keeps tripping the GCFI outlet on the Generator right away. I’ve tried changing many settings and googling I can’t find out why?! I’m trying to charge the battery bank with 120v AC like it’s intended to do through the AC Input I should be able to.
I’m able to get it to “work” if I disconnect the battery bank, via the breakers built into the batteries. Then the MPP shows 120v input and stays on. And the Generator outlet does not trip. As soon as I re-connect batteries it trips. It can’t change batteries if they’re not connected obviously so I’m in need of help please. If anyone is using the MPP 6548 let me know if you can charge with a generator like you should be able to.
NOTE: the GCFI outlet on Generator is 15A
