they are on plastic. Thick rubber like plastic and under that is wood.I just re read that you have a ground wire from the batteries to the inverter. If the batteries are sitting on damp concrete, that's the problem.
Did you forget to link the video?Here a video. In this scenario it wasn’t even charging but you can hear something inside AIO clicking on then off.
Wood can be conductive.they are on plastic. Thick rubber like plastic and under that is wood.
Ground wire is ran from the inverter AC ground terminal to the battery case Ground lug.I thought those units didn't have chassis grounding lug.
@AZ Off-Gridder why would you do this?Ground wire is ran from the inverter AC ground terminal to the battery case Ground lug.
That's how I read it, anyway.
What????@AZ Off-Gridder why would you do this?
The only thing connecting the battery to the inverter is 2 cables. Battery positive and battery Negative. Sorry if there was any confusion there@AZ Off-Gridder why would you do this?
Yes but thick rubber floor In the shed negates anything the wood can do.Did you forget to link the video?
Last year a guy had a fire because he covered his battery terminals with a sheet of damp plywood.
Just paste a linkAs to the video, I’m sorry I don’t know how I can share it on here yet…
He was very nice we tried lots of things ultimately we decided that it’s not charging correctly due to the generator. I need to try a different GennyWhat did watts247 have to say?
What about the double n/g bond issue?He was very nice we tried lots of things ultimately we decided that it’s not charging correctly due to the generator. I need to try a different Genny
