Yes. And we need consequences for those who don't."Please stay on topic" in ALL threads...do we need that?
... and who decides what is, or is not on topic? While a blatant derailment may be obvious, a slight side-step to the direct subject can often result in a gain to all involved.Yes. And we need consequences for those who don't.
That reminds me of a story. I had set out to install some new solar panels one morning when the phone rang . It was my neighbor and he needed a hand fixing his truck. The truck was a Toyota which as everyone knows is from Japan. Why is it we import trucks into our country instead of making our own?Occasional off-topic technical digressions are one thing but all too often it veers off into completely irrelevant rambling.
I mean, we're boomers...complex questions require anecdotes, metaphors and shaggy dogs until we've weaved a novel. lolI think the point is to stay on primarily technical topics. I don't mind when my threads veer from one technical topic to another. Maybe you start off talking about fuses and you end up talking about charge profiles and that's fine with me. The OP of the thread can say if they don't want to veer.
That fact that you put 60seconds of thought and typing into this gave me a chuckle... and who decides what is, or is not on topic? While a blatant derailment may be obvious, a slight side-step to the direct subject can often result in a gain to all involved.
So, something like a beer-buying offense?Yes. And we need consequences for those who don't.
What are you talking about? It must be just you who's seeing it.Title. And its way too big. 50% size would still be overkill.
I went up on the roof to wire the combiner box. I knew i needed 6 ferrules, so I grabbed 7 "just in case". When I got to the roof, I had 5. Granted it wasn't 60 miles, but it was a 13' ladder and it was snowing and 11pm and 22f outside.Went out to pull some old panels off a pole mount and replace them with new bifacials. Thought I had everything ready, nuts, bolts, mc4 connectors, wire, everything ... drat, 1piece short of channel strut and I'm not making a 60mile round trip to get another stick.
Don't you hate it when that happens.
Yeah, that huge banner is space that could be earning some advertiser dollars for the site.
I used 3/8" aluminum plate, 3/8" all-thread covered with 3/8" taigon tubing. On the end I used a fender washer over top of a valve spring out of a 2015-2021 corvette LT4 engine. Cranked down to 10inch pounds for 4 bolts applies the minimum 3000 newton compression. During it's expansion of ~3% the compression increases but does not exceed the maximum of 7000 newtons.How do you all compress your diy lifepo4 cells?
I feel like this topic never gets the attention it needs...
I like it!I used 3/8" aluminum plate, 3/8" all-thread covered with 3/8" taigon tubing. On the end I used a fender washer over top of a valve spring out of a 2015-2021 corvette LT4 engine. Cranked down to 10inch pounds for 4 bolts applies the minimum 3000 newton compression. During it's expansion of ~3% the compression increases but does not exceed the maximum of 7000 newtons.
