Poll: What BMS(s) are you using in your system(s)? (LiFePO4 only)
Index of most commonly discussed BMS' on this forum, with pictures and links to relevant resources. (click to expand)
Please keep responses concise and avoid discussion/commentary. Replies should follow the format:
For example:
As best I can tell this unbranded/generic BMS has alternately been called the 'Battery Hookup BMS', the 'DYKB BMS', and 'Overkill Solar BMS,' which all refer to specific sellers not the manufacturer or model name (JBD-SP04S020). The manufacturer appears to be JBD / Jiabaida, and the model # is JBD-SP04S020. Forum megathread can be found here, and video of the BMS here.
If your BMS looks like this:
With a Bluetooth app that looks like this:
And references JBD, Jiabaida, or Xiaoxiang, and/or LLT Power or LithiumbatteryPCB your BMS is likely the JBD-SP04S020 or a close cousin.
Overkill Solar on Amazon (forum member and well regarded responsive seller)
DYKB Store on Aliexpress
JBD Store on Aliexpress
The "Ant BMS" is an unbranded/generic BMS is not always easy to identify. It is sold through the DYKBhuang store, ICGOGOGO store, and others on Aliexpress and Ebay. Sometimes "Ant BMS" is printed on the PCB or on the label (or a little Ant head logo), sometimes it is not. Usually it is not mentioned in the product description or title. The Bluetooth App (I am told) references Ant BMS. Forum discussion of Ant BMS here, video review here.
There is more than one model of Ant BMS. Used here (and generally on this forum), Ant BMS refers to the one pictured above and featured in Will's video here. It can be identified by its balance lead connectors on the short side and flat rectangular heatsink.
There is another BMS by the same name (see here), which has the balance leads on the long side, and is often referred to as 'Ant BMS 2019 version' or 'new version'. To my knowledge, no forum members have purchased or tested this version of the Ant BMS.
update: there is an alternate (3rd party) app available in the play store for the ant BMS called VBMS (not sure if its available for apple). It is a paid app.
The distinguishing feature of the Heltec Active Balancing BMS, is that it is the only commodity FET based BMS I am aware of that does true active balancing (i.e. transferring energy between cells, as opposed to burning off energy from high cells). It can be identified by the black metal case with either capacitors visible on the front or a cover over the capacitors with a QR code. I believe it is sold unbranded to some resellers, but can be bough directly from Heltec via Aliexpress, Alibaba, or Heltec-BMS.com. Heltec sells many other BMS, including high current models, which do not have active balancing but may be worth looking into. They also sell active balancers ("capacative" and "inductive").
Heltec, is also known as Chengdu Heltec Automation co. ltd., Heltec Automation, and Heltec BMS. I believe it is also sold under the alternate brand name JKONG or JiKong (with a little cloud logo).
Catch all category for everything else, please specify and provide a link
If you do not use a BMS with a DIY pack / raw cells choose none
- BMS Name
- Your Cell Configuration (system voltage)
- Rated Discharge Current
- Cost (including accessories--to clarify, not entire system just BMS accessories like relays, temp sensors, etc)
- Satisfied (Satisfied, Mostly Satisfied, Somewhat Satisfied, Not Satisfied)
- Optional link to product
For example:
- JBD Smart BMS (JBD-SP04S020)
- 2P4S (12V)
- 120A
- 115 USD
- Mostly Satisfied
- Overkill Solar Branded JBD-SP04S020
