2020 POLL: What BMS are you using in your system? (UPDATED)
2020: What BMS(s) are you using? (more than 1 option can be selected)
  • Total voters
    206
Poll has been updated:
1. Heltec BMS (active balancing) has been added to the Poll
2. Heltec BMS entry w/ pictures and links has been added to top post
3. Ant BMS app screenshot has been added
Also those of you who bought a BMS from Overkill Solar, you have a JBD Smart BMS, please select that option in the poll, not 'other'.
Chargery 16T
300A discharge, 200A charge relays
Including the new SSRs about $400
also
16 Deligreen 1S active balancers $300
Very satisfied, even though the the Chargery menu sucks donkey dongles
Reactions: Dzl
  1. Chargery BMS16T-600
  2. 16s
  3. 300 (DCC-300HB)
  4. $296 (BMS, Shunt, DCC) (shipped + paypal fee)
  5. Mostly Satisfied*
  6. Directly from Jason (jasonwang3a@163.com)
* I haven't built the final system yet. I've tested 4s and 8s configurations with this unit (I have 2; will make 2 separate 48v packs combined in parallel).
Upcoming versions of the Chargery (e.g. active balancing) would probably change 5 to Satisfied.
Reactions: Dzl
Here are 5 more BMS products to add to this list. These are not cheap, then again neither are some of the Chinese products.
Moonitor 16S -
BMS123 Smart BMS -
Zeva 16S BMS -
REC BMS -
TinyBMS -
Thanks,
For now these BMSes will stay relegated to the "Other, Please Specify" category, there are a ton of BMSes out there and I'm trying not to overwhelm people with choices or discourage participation. I'm counting on the people who select other to specify which BMSes they have so I can see what options are popular and add them to the list.
I think 123smartBMS, TinyBMS, and Rec BMS have a chance of fighting their way onto the list, haven't personally come across the Zeva or Moonitor or heard anyone here mention them, I'll look into them though. I appreciate the links. For one reason or another there isn't much discussion or exposure to the higher end BMSes on this forum.
TinyBMS and 123smartBMS in particular are two I would like to learn more about.
I just added my vote for the Heltec. I only knew it as JK or Ji Kong. That is what is silk screened on mine.
14S6P of repurposed LG Chem Chevy Bolt 60 amp hour NMC cells.
Reactions: Dzl
  1. Daly 200a 4s
  2. 4s (2 12v batteries in parallel each with own BMS)
  3. 250a (30a inverter)
  4. $115 each.
  5. very satisfied
  6. aliexpress.com
  1. JK-B2A24S20P
  2. 18S (54V) / 280Ah
  3. 200A
  4. AU$249
  5. Currently ?: Satisfied (so far)
Reactions: Dzl
1. Chargery BMS8T-300
2. 2P4S (380AH 12V)
3. Using cheap relays to remote control devices
4. $90 for BMS + $42 DHL shipping
5. Satisfied
Reactions: Dzl
  1. SBMS0
  2. 4S20P (12V)
  3. 160Ah (1C)
  4. $149 SBMS (v03d) / $75 DSSR20 (3 x v02)
  5. Super Satisfied
Reactions: Dzl
  2. 16s
  3. 300 (DCC-300HB)
So #5 goes to NOT Satisfied after running with 16s for a while. I've dumped the Chargery.
1. Orion Jr. 2
2. 2p16s
3. Technically N/A. I used a Gigavac GX11 with a smaller relay to drive it (relay signal max is 175ma). Good for 200-300 amps.
4. $822 including relay
6. https://evolveelectrics.com/collections/orion-bms-jr-1-16-cells-in-series/products/bms-orion-jr-02
* It's complex especially in a CANBUS-controlled scenario. It's designed for EVs and not stationary systems, so getting it to behave the way I want has taken many many hours of experimentation and tuning.
Reactions: Dzl
1. SBMS
2. 2P8S 24v 190ah
3. 380AH
4. $150.00
5. Runs as advertised am pleased
6. Electrodacus.com
Reactions: Dzl
Hi,
Maybe someone on this thread can comment on a brand that will taper off the charge as cells are deemed 100%. I got 16 cells for 51.2 volts.
That's not a function of the BMS, the cells being nearly full causes the charge to taper off. My SCC goes to Float once the EndAmps is below 10A @ 61.9V Absorb. Once that point is reached the Ah is almost always @ 260Ah (my Capacity Setpoint for 18 x 280Ah)
dRdoS7
