jameshowison
- Jul 30, 2021
- 195
I was replacing a cell in a server rack battery. The BMS is a Pace BMS.
All was going well (voltage across the battery showed ~52v) until I went to put the white connectors back onto the board. See attached pic. When I put the second one in there was a “pop” sound and I smelled some smoke
I checked the voltage on the balance/sensing wires and all seemed correct (around 3.29 volts between each consecutive pair, ~52 across first to last)
Now when I attached everything and turn the BMS on it shows 0 volts for everything.
Perhaps I was putting the white connectors on upside down? Is that possible? They connectors have temp sensing wires in the as well, I think (the black pairs on the left of each plug).
Reckon the BMS is fried, right?
