We will pretend the inverter is 2000 watts and size accordingly
You will need...
2 of these
Blue Sea Systems 1991B PowerBar 1000, 12 3/8" Terminal Studs and 16 Screws - Bulk Packaging is in stock and ready to ship. Order today!
www.waytekwire.com
9 of these
Eaton's Bussmann Series CFBAR1-M8XSP (CBBF-MBC) MRBF Mounting Bars with M8 stud and 3/8" mounting hole work with CBBF Series Fuses and available at Waytek.
www.waytekwire.com
7 of these
Eaton's Bussmann Series MRBF-150 Marine Rated Battery Fuse, rated at 150A for 58VDC systems with bolt-down design are available at Waytek today. In stock, order today!
www.waytekwire.com
1 of these
Eaton's Bussmann Series MRBF-300 Marine Rated Battery Fuse, rated at 300A for 58VDC systems with bolt-down design are available at Waytek today.
www.waytekwire.com
1 of these
Eaton's Bussmann Series MRBF-100 Marine Rated Battery Fuse, rated at 100A for 58VDC systems with bolt-down design are available at Waytek today. Order today!
www.waytekwire.com
Here is the topo.
It is human readable and textual.
The dc legend block explains the atoms in the dc domain block.
