"portable" here means ground mounted panels which COULD be relocated if desired...
a) is this the correct order of components? This is just really rough. I'll post a schematic to the group later but I want to make sure i even understand the order of the components
LEGEND:
| = panel
___ = connecting wire
--> = last panel wire
--- = wiring
sc = solar charge controller
very simple schematic
| ___ | ___ |___ |___ |___ | --> scs ---- bsm ---- 13kwh (4 280ah eve groups of 4) --- 5000w inverter
b) does each battery (4qty 3.x EVE cells for a total of 280ah) - looking for 4 total 280ah batteries need it's own bsm? what does that wiring look like.
c) is the inverter size based on the max # of watts you would be able to power at a given time?
LEGEND:
| = panel
--- = wiring
