Post Battery Bank and Inverter! (pictures only)
70 kwh of DIY Tesla Model S batteries - designed room for 100kwh - 6 modules to go
Dual XW Pro's with PDP to the right and 4 60 amp/150v charge controllers to its right
(the wood "bridge" is a temporary path to get to crawl space beyond, where I am doing some sewer replacement, cast iron to ABS. it will be removed after the work is done)
AC side, 100 amp transfer switch on left, 100 amp loads panel center, chargeverters right, generator panel bottom right, on top of raceway. Bottom left relays to turn on chargeverter when battery low
power-wall-highlighted-jpg.220728
