“Combiner Box” on the left with PV protection, an ATS which uses the grid as “backup” and a 2000 watt grid connected power supply for charging batteries on cloudy days while keeping the inverter off grid for stable voltage. “AC Box” on the right with main grid disconnect, load, and a separate breaker for the inverter, with a relay and a contactor for connecting/disconnecting the grid. To the right of the inverter is “5v” for ESP32s, relays, a Raspi running Solar Assistant, and a Nano router with a 4-port Ethernet hub. To the left of the inverter is a busbar and 250A breaker for the batteries.
10 kW Deye inverter
12.65 kW of solar
32 kWh of Seplos batteries
