bestconcreteblock
- Dec 5, 2022
- 136
View attachment 232951View attachment 232952My DIY Solar Carport
Will do in the morning when the sun comes out.
Looking to build a mobile ground mount system... only for 600w total so (6) 100W panels. I'd love to do a pole mount setup but I won't likely be able to do that since I don't plan on burring the pole in concrete...
Is all the weight of everything reliant on the shear strength of the screws/nails? or hopefully lag bolts
I spent a small fortune in lag bolts to secure the structure.
I'll be replacing the 4x4 Posts with concrete pillars later this year.
The concern is weight of panels and rectangular frame causing joints like this to fail/slip, effectively punching post up through PV panel.
Would like to see horizontal joist mounted on top of post. Maybe notch post so joist bears its weight on top and extended part of post allows screws from the side. Or joist entirely on top of post, with board or plywood gusset on the side screwed into both.
You could add a bracket after the fact. Once you're in the deck section at your local big box store you'll see all sorts of things like this for less $2 each. They also add a lot of rigidity to the whole system helping to reduce twist.Would like to see horizontal joist mounted on top of post. Maybe notch post so joist bears its weight on top and extended part of post allows screws from the side. Or joist entirely on top of post, with board or plywood gusset on the side screwed into both.
Lets keep this thread to member builds of their ground mount either home-made, store bought or Frankenstein.
No questions or comments on the setup, just members post their mounts only with details below. I want a thread where people can scroll through everyone's post/pictures and see what their setup is and get ideas what might work for them instead of searching for days at every thread. If you have questions or comment about a build, message the member directly. I (and probably other people too) just want to scroll down and see the setups. Just hit the Like button and that is all. Please no comments or questions.
Details of your ground mount system including some detail about your setup. EX. - total KW size of ground mount built for, overall dimensions, what size ground contact posts you used (PT, Poles, I-beam...) Costs to build and maybe a picture if you did something unique (single axis, adjustable, etc..), your location (Canada vs FL will have an impact on design), what manufacture you purchased from if store bought
4-6 Picture of Overall ground mount completed, picture with some panels on but still being added so we can see the mounts/bracing under the panels, how it's anchored into ground (concrete, screw anchor, wires, etc..), picture behind the panels. pictures of how the vertical posts are connected to panel posts (some people use lags, u-bolts, etc..) We don't need overloaded with every single angle and every nut and bolt. This is just to give a "tease" so if someone likes your setup, we can message directly and get more information.
Thanks for playing!!
My ground mount is behind the house in full Texas south sun. Belle, the guard cow, patrols, mows and fertilizes the area.Lets keep this thread to member builds of their ground mount either home-made, store bought or Frankenstein.
Yes, if they are producing power
Ok.Yes, if they are producing power
Ahh, the beauty of simplicity doing the best you can with what you have!8.2 kw in 3 arrays.
Yes 3 decks, top level deck is main level/entry way. Unfortunately here is the compass alignment.If that's south facing I'd just mount them vertical on all those railings you have on three decks?
