Is it possible to operate a Magnum PAE4448 inverte/charger directly from solar panels with micro inverters?
This 120/240 inverter/charger is ordinarily connected to an AC source for battery charging, and a DC battery bank connected to the inverter "side".
Off grid the battery bank is charged by the DC solar panels until a genset is activated and the Magnum automatically switches to battery charging.
Solar panels with micro inverters produce AC current so could they be the AC source for battery charging instead of a genset?
A further complicated question is about using the grid tied panels with micro inverters to operate the battery charging function of the Magnum when the grid is "down"? When the grid goes down the panels sense no connection and shut down until the grid is reactivated.
Say a generator interlock kit is installed in the electrical panel. Using this the main breaker to the grid is turned off, the interlock slides down blocking that circuit breaker from being turned on, and freeing up the breaker for the genset circuit to provide power to the electrical panel.
Instead of a genset plugged into that circuit you plug the Magnum into that circuit and supply inverted power from the battery bank to the panel. I know this works successfully. (note the battery charging system on that inverter is not functioning)
Now if the charging circuit of the Magnum was wired into the electrical panel and the solar panels with micro inverters are connected to circuit breakers in that electrical panel, would the solar system sense that there was AC power to the electrical panel and come back on line, thereby providing AC power to the electrical panel and the battery charging side of the Magnum?
This is very convoluted and hard to put into words. Just trying to figure out how to use all those panels with micro inverters on the roof to charge the backup battery when the grid is down.
Appreciate any thoughts from folks who know more about this than i do!
