Now-Feb are low production mounts from an average of 1200 kw in the summer to 600 in the winter. From an 8.64 KW systemLooks like we really take a hit on solar production in the winter months even down here is Florida..
Was getting 60kwh-70kwh a day in on Home System .. Now getting 25-30kwh (~34-42% of prior)
Was getting 20-26kwh a day in RV system .. Now getting 11-12kwh (~46-55%)
Is this a normal year? Something that has a bit of a impact, as does usage, that is way down as A/C usage is way lower in winter months.
I believe Grid is ok for smaller systems/inverters especially when you have 1:1 net metering reduces the cost of extra batteries and help with big load/ start up for small inverters.I keep thinking that I should switch to a spare Growatt for grid charging, so that Solar Assistant can track it. But then I remember that the end goal is to never use the grid. So, it would be a waste of time to implement it. lol
My guess is peaking at ~70 KWh / day in late June. 45 in OCT, and 30 in Dec. I dont know where you are so that would help.Sooo....
I've been battling low PV production on a new system I've installed.
-(48) 400-500W bifacial aptos panels
-3 EG4 6000XP Inverters
-3 EG4 Wallmount Batteries
We wired the three separate batteries to each inverter respectively and also wired the three batteries in parallel.
When we first commissioned our system, we were instructed by two separate Sig Solar technicians to configure the batteries as a "shared battery" system. After a few days, I noticed the panels even on full sun would not produce more than 8500W total, very meager despite the potential power they SHOULD be producing!
I had a nagging feeling that something was capping or clipping the PV power based on the data charts, and what really got my attention was the amount of watts it was producing. I know the inverters are designed to accept up to 8kW of PV, I thought: "8500W is pretty close to 8000W", maybe the inverter in only allowing a maximum amount of power because it doesn't know there are three separate batteries???
I decided to call Sig. Solar one more time before I went down the road of calling EG4 directly and it paid off! Tech support instructed me that because each inverter has one battery attached to it, the "shared battery" function shouldn't be on.
Low and behold, the system today started to produce almost double the amount it had done the previous day.... I'm very curious how much power this system will deliver later in the year. Any thoughts on what I could expect?
Whenever I say grid, it's only for backup.I believe Grid is ok for smaller systems/inverters especially when you have 1:1 net metering reduces the cost of extra batteries and help with big load/ start up for small inverters.
That's excellent. I got 1.4KWh on a 14.55KW array.Consider yourself blessed! Some days I get 2. Yes, 2 KWH on a 6600w arrayView attachment 273129
You must have installed more PV between September and October.That's excellent. I got 1.4KWh on a 14.55KW array.
Things are definitely looking up. I beat Dec already.
I shattered last Jan.
Mid October, 14th iirc, I closed the disconnect on my 3.7KW SW facing tilting array.You must have installed more PV between September and October.
No way you only got 200 KWh on me in July with over double the array.
Lol thanks, yea that was snow.But congrats on the 1.4 you got!
Snow cover or?
For the diyer wood is a nice option and can often be gathered locally.I am very lucky most years I do not have a deal with heating more then a morning here or their, at most 4 days a year. This year I had to deal with the last week under I have much better understanding of heating in the winder months with little or no solar. Yes is was mild compared to what you folks get, but wow.. If I did not live in Florida I would move after this week.. lol … I assume thee is a lot of alternative heating methods like, gas, propane, oil and so on.?
Yeah I have two heat pumps, but I wake up and I have used 4kwh already .. just heating,, yeah I would not depend on power for heat… got to be alternatives.. it worries me they control the on/off switch to the big sources, why the resistant to be sell reliant…For the diyer wood is a nice option and can often be gathered locally.
NY state is pushing heat pumps hard, but the other day I saw someone saying they had 400A service, and that was because the heat pumps resistant strip heaters could pull 30kW....personally I think it's crazy to become dependent on electricity for heating in north east winters, at least with propane you can light your stove for emergency heat, have hot water etc. Just look at the recent buffalo snow disaster. If those folks didn't have gas there would have been many more deaths.
That is not what I was hoping for.... but we'll have to wait and see what happens. I calculated 20kw per hour, for at least 5 hours on sunny days.My guess is peaking at ~70 KWh / day in late June. 45 in OCT, and 30 in Dec.
Where are you?That is not what I was hoping for.... but we'll have to wait and see what happens. I calculated 20kw per hour, for at least 5 hours on sunny days.
With 22kW of panels getting 20kW out of them regularly seems tricky.That is not what I was hoping for.... but we'll have to wait and see what happens. I calculated 20kw per hour, for at least 5 hours on sunny days.
Solar is a bell curve. I normal only get 90+% for 1.5 hours / day.. I calculated 20kw per hour, for at least 5 hours on sunny days.
