I've seen the argument frequently that one could build a battery/inverter/charger system for much cheaper than buying a power station. When I priced a good battery, inverter, and charger it doesn't seem to be cheaper compared to a good power station. I do see an advantage that you get the exact components you want instead of what is put into the power station. Is there something I'm missing?
From my experience on having both setups and if I can do it all over again, I would go with the all in 1 system.
A lot of people never factor in the extra costs when doing a comparison like this. Costs like time, wire, wire lugs, fuses, extra shipping fees and others small stuff that doesn't come to mind right now, but add up rather quickly.
Right now good Batteries, MPPT chargers, Inverters, fuses and wire usually cost more than an all in 1 system. From the research I've done, I can pretty much get a all in 1 system for the price of the what good lithium batteries cost alone.
Also, an all in 1 system has a much smaller footprint so you have more space to work with in a build. I Mounted panels on the roof of my Van for charging, but you can always get some portable panels that can be really convenient.
And if you ever lose power at home, you can just bring it inside and not have to worry about running a gas generator.
