Still not clear on what you are looking for. Are you looking for a bench power supply with precise continuous voltage and current adjustments, or are you just looking for an internal AC to DC power supply with fixed outputs between 12 and 48VDC? What is your price range? How many amps does it need to supply?yes but a reliable one
its about one of Wills videos where he made a milk crate solar controller box. He used the Drok. You can see the video on his YT channel. That's the use I was after.
What do you mean by 2.6v? The battery Will used if I remember correctly was a 12 LiFePO4 battery. That is 14.6V max. Individual LiFePO4 cells run at 3.65V each. So I don't know what you are talking about. But if for some reason you have some cells at 2.6V then yes it is supposed to support 0-24V or 0-48V depending on which power supply you are talking about. I don't have one though so I have no idea how good they are for your purpose. To help you better you need to provide more information about what you have or want to have. There are too many things on the table, and I can't see what you are pointing at.Will the Drok do 2.6v for individual. cell balancing?
I see, you want to build what Will built.
In his latest version of the milk crate backup power system he used the Drok 10A variable voltage constant current power supply. Its the one I linked to above. He says he likes that model the best. If you read the reviews, most seem to like it. However there have been some reported problems with the labels for the terminals and some component failures. Just like any other brand. For the price its a good power supply.
For the purpose of charging, all you need is any variable voltage power supply that can go up to 14.6VDC (12V LiFePO4 battery). So you don't need anything with a higher voltage than that. That means you can look for 24, 36, and 48 VDC power supplies. Drok sells a 20A 24VDC version of the same thing that Will used that would charge your battery twice as fast at the same price.
You can also use these alternatives:
Amazon.com: IMAYCC 110V AC to 48V DC Converter Max 480W 10A,0-48V Adjustable Power Supply with LED Display,Variable Switch Transformer Regulated 5V 10V 12V 24V 48V Buck Converter for CCTV Computer Lab. : Electronics
Amazon.com: IMAYCC 110V AC to 48V DC Converter Max 480W 10A,0-48V Adjustable Power Supply with LED Display,Variable Switch Transformer Regulated 5V 10V 12V 24V 48V Buck Converter for CCTV Computer Lab. : Electronicswww.amazon.com
There is no guarantee any of these power supplies are going to be better than the Drok. I would just buy the 24VDC@20A Drok. If you go any more expensive than $40 on one of these power supplies, you would be better-off buying a 12V LiFePO4 battery charger. A charger will be constant current and then constant voltage, whereas the Drok will just be constant voltage. The charger may also turn off automatically when done and won't be accidentally adjustable to a voltage greater than the battery can be charged at. You are better off with the charger not the power supply.
For example:
You can also get some good 14.6VDC LiFePO4 chargers on what
A charger will be constant current and then constant voltage, whereas the Drok will just be constant voltage. Can you explain this please?I see, you want to build what Will built.
There is no guarantee any of these power supplies are going to be better than the Drok. I would just buy the 24VDC@20A Drok. If you go any more expensive than $40 on one of these power supplies, you would be better-off buying a 12V LiFePO4 battery charger. The charger may also turn off automatically when done and won't be accidentally adjustable to a voltage greater than the battery can be charged at. You are better off with the charger not the power supply.
For example:
You can also get some good 14.6VDC LiFePO4 chargers on Aliexpress.
I don't know anything about it. It says it has 7 stages. Nothing needs 7 stages. Like I said all you need are 2 stages. Everything else is a gimmick or related to after the charge is over. That is usually for trying to revive dead lead acid batteries for example or maintaining a float charge after charging. Its an awfully expensive charger for a 12V battery, and is only 15 amps. Sounds like a trickle charger for a boat to me. You can probably use it for other things as long as it supports the right voltages.What about this Victron?
Thanks for the breakdown. Wish Will would have explained this in video because it is hard to grasp for beginners. I returned the Drok and will get a charger at some point. Im in a van and there no free AC outlets so not important. But I did use it to charge my Jackery 1000 for back up, I got Drok up to about 13 volts, maybe 14, could not get 14.4 but I got 200 watts, 50 more from using Jackery charger. Now using 600 watt invertor to charge Jackery.I don't know anything about it. It says it has 7 stages. Nothing needs 7 stages. Like I said all you need are 2 stages. Everything else is a gimmick or related to after the charge is over. That is usually for trying to revive dead lead acid batteries for example or maintaining a float charge after charging. Its an awfully expensive charger for a 12V battery, and is only 15 amps. Sounds like a trickle charger for a boat to me. You can probably use it for other things as long as it supports the right voltages.
After watching the video its sounds like it has two modes: one for lead acid and one for lithium ion whatever they mean by that. It may or may not suited for LiFePO4 batteries. The price range for LiFePO4 12V chargers is around $60 for 30-40A and down in the $40 range for cheap 10-20A chargers off aliexpress. I personally don't care if my battery charger has Bluetooth. I want a dedicated charger for the battery I am charging that has as high a current rating as my battery. The smallest batteries for storage are at least able to charge at 40A, and most accept 250A or higher. Especially in a 12V configuration. A 12V 15A charger will take days to weeks to charge anything large. It sounds to me like that charger is for trickle charging one lead acid battery. The size and its specs indicates this. If that is what you need then great. Better deals at harbor freight or anywhere else.
