Hi All,
I'm putting together a battery that is 12V 570ah (I have 12x 3.2V 190ah cells) and I'd like a power supply to charge/balance and a load to test it.
I see the 30V/10A power supply recommended a lot, along with the 150W load tester. Due to the size of my battery, I'm wondering if there is a bigger power supply and bigger load tester anyone can recommend? Ideally something "cheap" as I don't plan on needing them (and don't have much storage space) after the battery is tested and installed.
Thank you
Thank you
